Apr 29th, 2024, 10:00pm
comparing different bias current (Read 2523 times)
nobody
Feb 26th, 2004, 11:21am
Hi, all
Is it possible to make a circuit that can compare different
bias currents and that ouputs the maximum of compared bias currents ?
thanks
fehler
Re: comparing different bias current
Reply #1 - Sep 22nd, 2004, 7:39am
Hi, I do think it is possible.
You can use current comparator to give a logic output,
which controlling a set of switchs.  I think you can find
a solution in this way.
For current comparator, please ref to Baker, Li, Boyce's
analog design textbook.
regards!
