May 5th, 2024, 8:17am
how can i simulate pll's phase noise with HSPICE (Read 3347 times)
jeffyan
Mar 18th, 2004, 7:01am
how can i simulate pll's phase noise with HSPICE?
thanks in advance
jeff
August West
I'll get up and fly
away
Re: how can i simulate pll's phase noise with HSPI
Reply #1 - Mar 18th, 2004, 9:09pm
There are two cases to consider. If the phase noise is deterministic (due to deterministic noise on the supply, dead-band jitter, etc.) you just run a very long transient and post-process the waveforms to extract the zero crossings. If the phase noise is due to non-deterministic sources, such as thermal or flicker noise sources, you'll need to turn in your HSpice license for a SpectreRF license. And frankly, you'll be happy you did. SpectreRF is very cool.
-August
Spice_Oracle
Reply #2 - May 20th, 2004, 3:42pm
There is a new extension to HSPICE called HSPICE RF that includes oscillator steady state analysis and phase noise analysis.  If you are a HSPICE user, this might be the best solution since it allows you to use your existing HSPICE netlist and model libraries.
