Try doing:
setenv CDS_Netlisting_Mode Analog
before you start DFII.
This is required to use the Analog Design environment, and if I remember rightly, not setting it results in the symptoms you're seeing for the spectre netlister (the spectre netlister can work with both nlp and CDF based libraries, but needs to know which mode it is in).
