mas_serg
Thank you, jbd, for your reply. I've already forgot about that my question. It was so long time ago. I found solution about one year ago: 1. Add to the functional cellview line parameter td=300; // default delay time 2.Add on an instance "User Property" with name "verilog" and type "hierProp", then -> expand and name "td", type "string" and unit 'timescale. That is all. May be it will be useful for somebody.
Thanks and best regarges, Sam.
