Jul 20th, 2024, 12:21pm
about cadence manual (Read 3777 times)
stone
Apr 06th, 2004, 7:05am
I have  problems  in using  cadence.
Though  I can get help in the cadence software, I want to  have  a cadence manual  before I  use  the cadence software.
Can anyone have a cadence manual?
Can anyone help me ?
Re: about cadence manual
Reply #1 - Apr 6th, 2004, 10:27am
If using IC446 or later, type "cdsdoc".
If using IC445 or before, type "openbook".
This will start up the documentation system. In cdsdoc it
displays the documentation in web pages, although at the top
of the pages, there is a link to print the manuals or display in PDF
format - these are nicely formatted documents, rather than web
pages - so you can print them out.
There's an enormous number of manuals, so you'll need to find the one you want - a "cadence manual" is rather vague, since there
are many, many different tools that you could be talking about...
stone
Reply #2 - Apr 6th, 2004, 8:18pm
Hi Andrew!
Thanks for your help!
I want to have a  cadence manual  about the analog cicuit design. It had better be displayed in PDF format.
Can you help me ?
Thanks!
Stone.
Reply #3 - Apr 7th, 2004, 12:12am
Did you actually try running cdsdoc/openbook (depending
on the version) and then navigating around the manuals
to find a relevant one? In both documentation systems there
is a search engine too.
It's not hard. Try it before asking...
