If using IC446 or later, type "cdsdoc".
If using IC445 or before, type "openbook".
This will start up the documentation system. In cdsdoc it displays the documentation in web pages, although at the top of the pages, there is a link to print the manuals or display in PDF format - these are nicely formatted documents, rather than web pages - so you can print them out.
There's an enormous number of manuals, so you'll need to find the one you want - a "cadence manual" is rather vague, since there are many, many different tools that you could be talking about...
