Dec 14th, 2025, 1:16am
Calculating Period-to-Period Jitter into PhaseNois (Read 3361 times)
t_stoll
Apr 08th, 2004, 3:06am
Hi All,
I have a problem calculating a period-to-period jitter of a analog PLL into phase noise.
Can anyone of you give me an advice on or a hint where I can get more information about it?
Thanks in advance,
Tom
Re: Calculating Period-to-Period Jitter into Phase
Reply #1 - Apr 12th, 2004, 3:06am
Tom,
Try reading Ken Kundert's paper:
http://www.designers-guide.com/Analysis/PLLnoise+jitter.pdf
In the analysis section there are a couple of other cut down versions of this paper which cover just phase noise or just jitter, if the above paper is too lengthy.
