Misha
Hello Spectre gurus,
I encountered a problem while simulating a mixed transistor level + VerilogA circuit. It appears to be caused by insertion of a block named mvi_HF_core.va, although this same block simulates fine in a smaller schematics with few transistors.
Below is the error reported by Spectre: <BEGIN> ...... Error found by spectre in `NCH_LVA':`MN1', in `NA210':`NAND0', in `Probe_driver':`I38', during hierarchy flattening. `mvi_HF_ core' is being redefined. Internal error found in spectre in `NCH_LVA':`MN1', in `NA210':`NAND0', in `Probe_driver':`I38', during hierarchy flattening, during circuit read- in. Please run `getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com. Error detected in file `patch.c' at line 158. Assertion failed. <END>
I seem to recall having seen this before... There shouldn't be any name conflict - I tried 5 different ones already. Our Cadence support is still looking for an answer.
Any advice is really appreciated....
Thanks, Misha
