Jul 20th, 2024, 6:24pm
digital waveforms in spectreVerilog on Linux (Read 1511 times)
Perelman Yevgeny
Guest
Apr 08th, 2004, 12:15pm
For some reason I can not view digital waveforms after spectreVerliog simulation on Linux (the same circuit runs fine on Solaris).
I can browse to waveforms in the results file, and I find the names strangely flattened (i.e. X<7> becomes X_7). When I try to look at least on these "flattened" waves, I see constant zeros.
I'm sure the simulation itself runs OK, as all analog waves are correct - problem only with saving data.
Has anyone seen this?
Thanks a lot.
  IP Logged
