Perelman Yevgeny
Guest
For some reason I can not view digital waveforms after spectreVerliog simulation on Linux (the same circuit runs fine on Solaris).
I can browse to waveforms in the results file, and I find the names strangely flattened (i.e. X<7> becomes X_7). When I try to look at least on these "flattened" waves, I see constant zeros.
I'm sure the simulation itself runs OK, as all analog waves are correct - problem only with saving data.
Has anyone seen this?
Thanks a lot.
