Jul 20th, 2024, 6:28pm
Spectre error during pre-processing (Read 1925 times)
Misha
Apr 08th, 2004, 7:40am
Hello Spectre gurus,
I encountered a problem while simulating a mixed transistor level + VerilogA circuit. It appears to be  caused by insertion of a block named mvi_HF_core.va, although this same block simulates fine in a smaller schematics with few transistors.
Below is the error reported by Spectre:
<BEGIN>
Error found by spectre in `NCH_LVA':`MN1', in `NA210':`NAND0', in
       `Probe_driver':`I38', during hierarchy flattening.
   `mvi_HF_ core' is being redefined.
Internal error found in spectre in `NCH_LVA':`MN1', in `NA210':`NAND0', in
       `Probe_driver':`I38', during hierarchy flattening, during circuit read-
       in.  Please run `getSpectreFiles' or send the netlist, the spectre log
       file, the behavioral model files, and any other information that can
       help identify the problem to support@cadence.com.
   Error detected in file `patch.c' at line 158.
   Assertion failed.
<END>
I seem to recall having seen this before...  There shouldn't be any name conflict - I tried 5 different ones already.  Our Cadence support is still looking for an answer.
Any advice is really appreciated....
Misha
