Sep 17th, 2024, 1:36am
eye diagrams in cadence (Read 8057 times)
tony
Guest
Apr 20th, 2004, 10:23pm
hello
how does one make eye diagrams in cadence ? spectre or spectre rf ?
thanks
  IP Logged
Frank Wiedmann
Munich, Germany
Re: eye diagrams in cadence
Reply #1 - Apr 21st, 2004, 4:29am
In version 5.0, there is an eyeDiagram function in the Waveform Calculator (in the Special Functions menu). See the Waveform Calculator User Guide for details.
jbdavid
Reply #2 - Nov 2nd, 2004, 4:56pm
You can also use verilog-A
there is an eye_diagram_generator in rfExamples - or rfLib.. this works on a timer.. but if your recieve clock is from a locked pll with some jitter model, you might want one that resets based on a trigger signal.
you might check bmslib (ships with IC5.033 and above) to if the clocked version made it in there..
this generates two signals.. a horizontal sweep and vertical signal and you use those to do plot the vertical vs the horizontal..  to see the eye diagram..
Of course if you are interested in ensuring a sufficient eye-opening, you might rather check that directly..
which requires a different verilog-A or AMS model.
Jbd
jbdavid
