Sep 26th, 2026, 1:51am
Variable clock delay modelling (Read 3278 times)
Tom Johnson
Guest
Apr 21st, 2004, 6:40am
Im involved in a synchronizer project and need to model the system. I have 1 clock signal running at XMHz and need to create a phase shifted version of it, where the phase shift varies sinusoidally between +- Ømax.
Basically i need to create a block of code that performs a variable phase shift Ø(t), as shown below and am wondering is this possible?
Thanks in advance
Tom
                               variable delay block
                               _________________
                                                    Ø(t) = sin(t)
                              |________________|
  IP Logged
George Suarez
Guest
Re: Variable clock delay modelling
Reply #1 - Apr 29th, 2004, 4:24pm
Here is a code that I wrote for random numbers between A and minus A.
architecture random of random_num is
constant K : real := 1.3806503e-23;
signal Vth_op: real := 0.0;
signal rand: real := 0.0;
signal clk : bit :='0';
entity ... is...
end entity;
architecture ideal of .... is
signal rand1,rand2: real := 0.0;
begin
     clk <= not clk after Tshrn;
     process
     variable unf : real;
     variable seed1:integer := 2;
     variable seed2:integer := 123123123;
     begin
     wait on clk;
     Uniform(seed1,seed2,unf);
     rand1 <= ROUND(unf*10.0);
               --Multiply unf by 10 to obtain integer
     end process;
     break on rand1;
               process
     begin
     wait on clk;
     rand2 <= unf;
     end process;
     break on rand2;
   between_A_n_minusA == ((-1.0)**rand1)*rand2*A
end random;
This code may be freely distributed, I create it for a  course project. Hope it helps.
gEoRgiE
  IP Logged
