May 16th, 2024, 10:09pm
Zero crossing points of a differential ampr (Read 1545 times)
Vinit
NY,USA
Apr 22nd, 2004, 2:42pm
Hello.
 I have simulaion results of a differential folding amplifier for an A/D converter.
 I want to find out the zero crossings of the output waveforms. I found some article online, which found the zero crossing on the time scale using the calculator feature cross. I tried it and it doesnot work for me.
 Any suggestions on how can I get the zero crossings or basically plot the difference between 2 outputs of a differential amplifier.
 Thanks in advance !
Re: Zero crossing points of a differential ampr
Reply #1 - Apr 22nd, 2004, 3:44pm
How about subtracting one signal from the other in the calculator, and then using the cross function - you didn't give any clues as to what you'd actually done...
It ought to work, so I can only imagine you did something wrong. If you explain what you tried, that will help...
Vinit Dhulla
Guest
Reply #2 - Apr 23rd, 2004, 9:51am
Andrew,
 Thankyou very much for the reply. Actually, what I did was, select the wave button on the calculator and then select one of the waveform on my waveform window. Then I clicked on the cross button and then buffer output or something.
  I am using this for the first time and just followed the procedure,trying to see if something happened.But,I feel what you said is right, subtract the signal first.
   Can u just give me a brief idea on how to subtract signals and then plot zero cross or is there any documentation available that I can refer to.
    Thankyou once again.
  IP Logged
Reply #3 - Apr 26th, 2004, 9:49pm
Vinit,
If you have the two waveforms displayed in the waveform tool, hit wave, and then click on one waveform, then the other, and then hit the "-" button in the calculator.
Or use VT button and click on both nodes in the schematic,
then -. It's a reverse polish notation calculator, and so you enter the operands first and then the operator last.
Having done that (it will show as waveform1-waveform2),
you can then use cross as usual.
I suggest you read the documentation on the calculator (use the Help menu in the calculator to locate it easily).
Vinit Dhulla
Guest
Reply #4 - Apr 28th, 2004, 1:41pm
Thanks Andrew,
  Your suggestion was very helpful, I was able to do it.
Vinit.
  IP Logged
Vinit
NY,USA
Reply #5 - Apr 28th, 2004, 1:56pm
Hello ,
I can get the zero crossing for 1 pair of differential amplifier easily. But, I have 90 such zero crossings. Is there a shortcut to get all the zero crossings together or you have to repeat the same process 90 times.
Thankyou,
Vinit.
Reply #6 - Apr 28th, 2004, 10:09pm
Vinit,
Sounds like a good reason to write an OCEAN script to do this. You can then write some code to loop over the differential pairs and do the same computation on each, and print out the results.
Look in the OCEAN Reference Manual in cdsdoc (I think it is under the  Analog Design Environment, or something like that, in cdsdoc - I'm writing this from memory).
Frank Wiedmann
Munich, Germany
Reply #7 - Apr 29th, 2004, 12:06am
If you want to find all the zero crossings of a single expression, you can specify 0 as the edge number in the cross function of the calculator (this is documented in the Waveform Calculator User Guide). You will have use the print button of the calculator in this case.
Vinit
NY,USA
Reply #8 - Apr 29th, 2004, 3:36pm
Thankyou guys,
  I really appreciate your replies.  I think I am not able to make it clear what I want to do. Let me give it a try.
  Actually, I am trying to simulate 18 Folding amplifiers(folding rate = 5) together in some fashion. Each folding amplifier output generates 5 zero crossings and hence I have 90 zero crossings.
   Initially, I had problems of getting this zero crossing point on the Y-axis, which problem is now solved.
   Now, I am trying to study the variation in these zero crossings if I vary some other parameter. Hence I wanted to know a few things:
-- If I can get the value(x-axis) of these 90 zero crossings(ideal) so that I can compare them with the zero crossings after I introduce some mismatch. As you understand, it would be too difficult to first generate the zero crossing for each folding amplifier, note down the 90 values,then generate zero crossings with mismatch and measure each value and compare with the ideal value.
--So is it possible to automatically measure these values and print  to file, so that I can compare them easily.
I really thankyou for your help.
Vinit.
Reply #9 - May 3rd, 2004, 2:53pm
Vinit,
As I said before, OCEAN is the way to do this. You could
completely automate this using OCEAN.
