Vinit
NY,USA
Thankyou guys, I really appreciate your replies. I think I am not able to make it clear what I want to do. Let me give it a try.
Actually, I am trying to simulate 18 Folding amplifiers(folding rate = 5) together in some fashion. Each folding amplifier output generates 5 zero crossings and hence I have 90 zero crossings. Initially, I had problems of getting this zero crossing point on the Y-axis, which problem is now solved.
Now, I am trying to study the variation in these zero crossings if I vary some other parameter. Hence I wanted to know a few things:
-- If I can get the value(x-axis) of these 90 zero crossings(ideal) so that I can compare them with the zero crossings after I introduce some mismatch. As you understand, it would be too difficult to first generate the zero crossing for each folding amplifier, note down the 90 values,then generate zero crossings with mismatch and measure each value and compare with the ideal value.
--So is it possible to automatically measure these values and print to file, so that I can compare them easily.
I really thankyou for your help.
Regards, Vinit.
