Sep 18th, 2024, 9:19am
Suggest me the architecture of Ring VCO! (Read 2919 times)
VincentLee
Apr 28th, 2004, 1:05am
Hello everyone,
I am designing a VCO in a PLL which uses for clock generator in MCU. So its operating frequency is not very high, tuning range is about 10MHz~200MHz. And it will be implemented by CMOS 0.6um process with 5V power supply. In addition, the input control voltage also needs wide control range.
In many specs, I focus on the lower phase noise characteristics and higher PSRR. Firstly, due to the low frequency application, I select the Ring VCO. However, there are so lots of IEEE papers about the Ring VCO that I can't decide which one is best for me.
So please suggest me the achitecture of Ring VCO! I would like use the differential cascode structure to build my Ring VCO, how do you think about its performence?
Thanks in advance!
Vincent
try my best...
Augustine B Lytan
Guest
Re: Suggest me the architecture of Ring VCO!
Reply #1 - Apr 29th, 2004, 11:21am
 The delay with balanced loads by maneatis is one of the most popular one as it has very good psrr. you can have a look at the paper:
Low-jitter Process-Independent DLL and PLL Based on Self-Bias Techniques
Author: John G. Maneatis
IEEE Journal of Solid-state circuits, Vol 31, No 11, November 1996.
Hope this helps.
        augustine.
  IP Logged
