I use a resistor string to get ref+, ref-, and CMO for a pipelined ADC. The resistor string is shown below.
R1 R2 R3 -----^^^-----^^^------^^^-----| ref+ cmo ref- gnd where R1=R2=2.25K, R3=5.5K. Just now I argued with another guy about the layout of that resistor string. Here I have two questions.
The first, is it necessary to match R1 and R2?
The second, draw 4 parallel resistor strings shown below
R1=9K R2=9K R3=22K -----^^^-----^^^------^^^-----| ref+ cmo ref- gnd
the equivalent resistance is the same as the first structure. Which one has better matching? (Assuming that we use the equal width when drawing the resistors)
The sheet resistance is about 400 Ohm/sq. (n+ poly resistor with SAB, for SMIC 0.25um process.)
Best regards,
Yawei Guo
