May 6th, 2024, 12:03am
Cgs, Cgg, CGd etc. in cadence (Read 26057 times)
modern_analog
Jun 16th, 2004, 11:37am
Do the values of caps which we get from cadence .op carry any physical significance.
ie is Cgg = Cgs + Cgd + Cgb. In this case, should I take the modulus of the values.
I feel it is not the case, but just want to re-confirm, since some of the caps are negative (due to derivative of Q being negative)
If this is not the case, how can we have cadence give us the capacitance at any node and its constituents. For instance if cadence says node n1 has 1pf of cap, and node n1 has 4 transistors connected to it, how can we figure out which transistor is contributing how much cap and what are the constituents (Cgs, Cgd etc.) of that transistor.
We used to have captab option in hspice.
thanks
Re: Cgs, Cgg, CGd etc. in cadence-
Reply #1 - Jun 16th, 2004, 2:26pm
I assume you're talking about bsim3v3 models here.
Here's a note that I wrote some years ago on this:
Quote:
The values you are seeing are correct because the values of these
parameters are the partial derivatives of the terminal charges with
respect to the terminal voltages, so they can be negative.  They are NOT
physical two terminal capacitors.  See the UCB bsim3v3 documentation,
equations 4.3.28 - 4.3.31.
An earlier spectre implementation only gave the values of three
capacitors which were closer to the intuitive value of what the
capacitance should be, but many customers asked for the complete set of
partial derivatives, so that is what spectre currently provides.
Here is a summary of the differences in the capacitance operating point
figures between 4.4 and 4.4.1 BSIM3V3 models in spectre.
In the following section Cxx refers to the parameter calculated by
the bsim evaluator inside the code. The lower case cxx refers to the
value reported by the operating point.
In 4.4:
cgs = -Csg + pModel->OverlapCgs * pInst->Width * pInst->MFactor
cgd = -Cdg + pModel->OverlapCgd * pInst->Width * pInst->MFactor
cgb = -Cbg + pModel->OverlapCgb * pInst->Length * pInst->MFactor
cbd = Cjd
cbs = Cjs
In 4.4.1:
Cgsovl = pInst->pSDModel->OverlapCgs * pInst->MFactor;
Cgdovl = pInst->pSDModel->OverlapCgd * pInst->MFactor;
Cgbovl = pInst->pSDModel->OverlapCgb * pInst->MFactor;
cgs = Cgs - Cgsovl
csg = Csg - Cgsovl
cgd = Cgd - Cgdovl
cdg = Cdg - Cgdovl
cbd = Cbd
cbs = Cbs
cjd = Cjd
cjs = Cjs
Here's a mapping between the parameter name in 4.4, and what it
corresponds to in 4.4.1:
4.4    4.4.1
cgs = -csg
cgd = -cdg
cgb = -cbd
cbd = cjd
cbs = cjs
The parameter names are those reported by the operating point in the two
versions.
Using the above note, you can translate from the partial derivatives spectre outputs to be in line with the bsim3v3 specification, into the more traditional capacitance terms.
Note that spectre can also output a captab. See
"spectre -h info". You'll see that you can do what=captab
to output a capacitance table.
superwormsz
Reply #2 - Sep 2nd, 2004, 6:53am
I have a question
vdsat=vgs-vth????
Reply #3 - Sep 2nd, 2004, 10:55am
superwormsz,
That doesn't appear to be a question...
101questions
Reply #4 - Sep 2nd, 2004, 11:17am
Andrew,
Thanks for the clarifications.
What about channel to bulk capacitance? Is it counted as a part of cjs, cjd?
Reply #5 - Sep 2nd, 2004, 9:02pm
No, that would have been (traditionally) cgb. I just noticed a typo in my note above - I think it should say that the mapping should be:
Quote:
4.4    4.4.1
cgs = -csg
cgd = -cdg
cgb = -cbg
cbd = cjd
cbs = cjs
(cgb was wrongly saying it mapped to -cbd).
So if you want to find the channel-bulk capacitance, look at -cbg.
At least I think that's correct  ;)
101questions
Reply #6 - Sep 2nd, 2004, 11:12pm
Andrew,
I'm puzzled. Cgb cap is between gate and bulk, right?
Channel to bulk cap represents capacitance of depletion layer beneath the channel, if the channel exists, that is in strong inversion.
If we change the bulk potential of mos in strong inversion, while gate, drain and source are are constant, we charge cjs, cjd, bulk-to-channel cap, and that's it. Cgb in strong inversion is almost zero, at least in active area.
Am I missing something?
Reply #7 - Sep 3rd, 2004, 9:15am
You're probably right. It's years since I've really thought about this, so I'll have to spend some time checking things. Won't be for a few days, given other commitments, as well as being out of the office. Sorry...
modern_analog
Guest
Reply #8 - Sep 17th, 2004, 9:12am
This absolutely makes no sense...
I did a simple experiment. I took a common source transistor and put a voltage source with a resistor (R1) at the gate and a resistor (R2) at the drain.
pole at the gate of the transistor is 1/(R*C) where C is Cgs (not Csg) + (gain)*Cgd (not Cdg)
At the drain, I got a zero at gm/(Cdg) and pole at 1/(R*Cdb+Cdg)
Note the transistor was in saturation.
It seems Cgd = overlap of the gate, drain ~ 0
but Cdg is very high. In fact, I read somewhere that Cdg is proportional to Cgs(or Cgg to be more exact).
So, my question is
a) Is the above correct, ie gate cap is split between a big Cgs and very small Cgd.
b) How is Cdg calculated. It seems to be a big factor
c) In all the above Cdd ~ 0 because I had a postive Cds cancel a negative Cdg. Strange? That basically means, I should not consider Cdd in my equations.
ps: In all my statements above, I could have made a mistake with the correct cap values since they are so small.
These were representative values
Cdb=-24f
Cdd=1f
Cdg=-244f
Cds=267f
Cgd=.7f
Cgg=766f
Cgs=-800f
Csg = -365f
  IP Logged
Reply #9 - Sep 19th, 2004, 3:10pm
You also have captab in spectre (see spectre -h info), as
well as the explanations I gave earlier.
Reply #10 - Sep 24th, 2004, 11:22am
It should also be noted that some of the peculiarities arise from the BSIM3 implementation itself.  Philips' MOS Model 11 is supposed to do a better job, in terms of making the capacitance model reciprocal.  (With a nice non-reciprocal capacitor, one could power the world simply by driving the capacitor in a cycle and extracting energy ... Smiley )
cricket_fan
Guest
Reply #11 - Apr 8th, 2005, 12:09pm
In order to look at Cgg vs a dc bias voltage , I have to do a dc simulation but it looks like I need to have an ac source for simulationg capacitance.
I want to look at Cgg vs Vgb....in cadence.
thanks
MMN
  IP Logged
