What you could always do is to run one monte-carlo run at a time (via ADE, having hacked the netlist to change the seed), and then do a results->Save in the ADE window to save the whole run directory to another name.
Having done that you can then select a particular set of previously run results by doing results->select
BTW, why do you want to set the seed? An alternative to setting the seed might be to set the number of the first run - it means you've got the same seed, but you're further down the sequence of random numbers, which would effectively have the same effect (of course, making sure that your starting run number is greater than the number of runs in the first monte-carlo so the results don't overlap).
