May 18th, 2024, 12:00pm
simulating HSPICE netlist with Spectre (Read 872 times)
rfx
Jul 10th, 2004, 10:15am
I want to simulate HSPICE netlist with Spectre.
1) Is it possible to simulate a HSPICE netlist with
Spectre (or SpecterXXX) without changing anything in the HSPICE netlist?
2) I have tried to use (unsuccessfull by far)
spectrespp
spp -convert -iofile inp.sp out.scs
I got follwoing error message;
//--INFORMATION--// SPICE Reader : MDL @version 1.2.2 01/31/2003
//--ERROR--// SPICE Reader : "hspice.sp", Line 3 : Dot card .net is an unknown control card and will be commented out.
//--FATAL ERROR--// SPICE Reader : "hspice.sp", Line 16 : Syntax error caused by "opt1(".
spectre (ver. 5.0.0.060503 -- 05 Jun 2003).
Any advice OR suggestion is welcome!
(PS. People familiar with Eldo, I am looking for an option
in Spectre like in eldo; >eldo -compat -i inp.sp)
Re: simulating HSPICE netlist with Spectre
Reply #1 - Jul 13th, 2004, 2:18am
You should try IC5141 (now released) where you can do:
spectre -csfe hspice.ckt
It has pretty good compatibility (-csfe tells spectre to use
the new front end, which can natively parse both spectre and SPICE netlists).
rfx
Reply #2 - Jul 13th, 2004, 7:48am
Thanks Andrew.
Reply #3 - Jul 14th, 2004, 5:45am
Just realised I made a typo. It should have said:
spectre +csfe hspice.ckt
i.e. it should be +csfe not -csfe.
