Please help me with the following questions, they have confused me a lot
1) In the spice parameters file provided by mosis (for example
http://www.mosis.org/cgi-bin/cgiwrap/umosis/swp/params/tsmc-035/n88y-params.txt), What does K' refers to, it says here that K' is (uo*Cox/2) but when i use this value for my simulations I dont get a correct result, rather this K' value is closer to uo*cox.
2) If I have to find Ro for a MOS transistor, i use formula 1/(lambda*Id), where lambda is channel length modulation factor, how can I find lambda using this spice file.
I dont want to find exact Ro for each transistor, but would like to know the approximate value which I should use for hand calculations and basic analysis.
Thankyou
