May 18th, 2024, 11:23am
Basic but confusing question regarding mosis (Read 4410 times)
Mohit
USA
Jul 18th, 2004, 1:00am
Please help me with the following questions, they have confused me a lot
1) In the spice parameters file provided by mosis (for example http://www.mosis.org/cgi-bin/cgiwrap/umosis/swp/params/tsmc-035/n88y-params.txt), What does K' refers to, it says here that K' is (uo*Cox/2) but when i use this value for my simulations I dont get a correct result, rather this K' value is closer to uo*cox.
2) If I have to find Ro for a MOS transistor, i use formula 1/(lambda*Id), where lambda is channel length modulation factor, how can I find lambda using this spice file.
I dont want to find exact Ro for each transistor, but would like to know the approximate value which I should use for hand calculations and basic analysis.
Thankyou
View Profile jn_mohit   IP Logged
Frank Wiedmann
Munich, Germany
Re: Basic but confusing question regarding mosis
Reply #1 - Jul 18th, 2004, 11:45pm
Quote:
1) In the spice parameters file provided by mosis (for example http://www.mosis.org/cgi-bin/cgiwrap/umosis/swp/params/tsmc-035/n88y-par ams.txt), What does K' refers to, it says here that K' is (uo*Cox/2) but when i use this value for my simulations I dont get a correct result, rather this K' value is closer to uo*cox.
Why don't you just ask them directly (or try the MOSIS User Group)? See http://www.mosis.org/support/customer.html.
The most simple and most accurate way to find Ro is probably to perform a dc sweep simulation and to look at the slope of the curve in the saturation region.
forestmay
Reply #2 - Aug 5th, 2004, 3:39am
after .dc sweep , u can use the following fomula in spice
.probe ro = par('1/gdso(m)')
to caculate the output resistance of the transistor m.
WHO can help me to caculate the Rout of a circuit, for instance  a casocde current source?
kokabanga
Reply #3 - Aug 6th, 2004, 11:31pm
same thing do a DC sweep of a dc output voltage source connected externally from o/p pin to gnd.....and then plot slope of iout wrt vout....this is possible in ide based simulators like ewb, cadence, mg..dunno in spice if u can plot slope
Undecided
naren
