Apr 26th, 2024, 5:17pm
Loss in unmatched line (Read 78 times)
R. Zakai
Jul 29th, 2004, 9:23am
Does anyone know how to estimate loss per unit length in an transmission line with standing waves (ZL=/Zr). I understand the loss is greater than the normal I2R loss for a flat (ZL=Zr) transmission line.
Rehan
Adrian
Guest
Re: Loss in unmatched line
Reply #1 - Jul 29th, 2004, 2:00pm
In general, the Mismatch Loss (dB) is:
-10*log(1-|gamma load|^2)
where |gamma load| is the magnitude of the load reflection coefficient.
  IP Logged
R. Zakai
Reply #2 - Jul 30th, 2004, 9:45am
I know that equation but is there a more comprehensive equation that also takes into account the length of the transmission line. To pose the question differently, will the loss be the same for a 0.1 meter and a 1 meter 50 ohm transmission line connected to two identical unmatched loads.
R. Zakai
