When you measure noise figure, you really need to specify the output of the noise analysis as a "probe" rather than as a pair of voltages.
When you do this, the noise analysis knows where the load is, and can therefore remove the noise from the load from the noise figure calculation (normally it would not be included).
You could of course make your output port have a noise temperature of -273.152 degrees C, and keep the output as a pair of voltages, but the right way to do it is really to just specify "probe" as the output type on the noise analysis form (or pnoise, or qpnoise, or whatever you're doing).
With sp analysis this isn't an issue, because you always specify the output as a port. However, if you are looking at contributors, you must be doing a conventional "noise" analysis rather than "sp".
Note, in all of this I'm assuming your load is a "port" component (you mentioned "vsin" at one point, which confused me a bit).
