Sep 29th, 2026, 8:24pm
Electrical to wreal interface (Read 1431 times)
aznaragorn
Aug 09th, 2004, 10:23am
I'm having some trouble trying to convert an electrical node to a wreal. I have a module within my top level module, whose output (voltage) i want to assign to a wreal at my top level. So something like:
module inside_module (out)
output out;
electrical out;
//behavioral code
module top_module ( out);
output out;
wreal out;
electrical inside_out;
inside_module mod1 ( inside_out);
//I want to do something like:
assign out = V(inside_out);
I keep on running into analog and digital interface issues when i try different solutions; the assign statement doesn't work because you can't sense transitions on analog access functions. I tried using a real to store the value in an analog block like this:
analog begin
      inside_out_temp = V(inside_out);
and then doing this:
assign out = inside_out_temp;
Unfortunately since inside _out_temp is defined in the analog block, it is also considering analog owned and cannot be assigned to a digital signal (the wreal out).
I must be missing something really simple here. Any ideas? Thanks in advance, this forum has been very helpful.
Also, is there any way of using connect modules, or something similiar for wreal to electrical and vice versa interfaces.
jbdavid
Re: Electrical to wreal interface
Reply #1 - Nov 1st, 2004, 6:48pm
What you have to do is
wreal out;
real out_temp;
assign out = out_temp;
analog begin
but you don't HAVE to have the analog block to access
the voltage, and you probably dont want
a digital event on every timestep,
So you might want to gate this with a sampleing clock
that could be a logic event
module top_module (input sclk, output out);
logic sclk;
wreal out;
real out_temp;
always @(posedge sclk) out_temp = V(inside_out);
// of course if you don't want an external event controlling the sample time, you can experiment
with simple fixed time periods or a threshold
based update
always @(cross(out_temp-V(inside_out)-vth)
               or cross(V(inside_out)-out_temp-vth))
I haven't tried that, because I've always found there is a good clock to use for the sampling function I need to use.
jbdavid
