Re: pac and pnoise disagreement
Reply #1 - Sep 8th, 2004, 6:09pm
In the paper on this subject that I have looked at most recently (Jitter and Phase Noise in Ring Oscillators, JSSC 6/99), Hajimiri treats flicker noise as a noise current with a 1/f spectrum that is injected into the drain. This is really not an accurate portrayal of the situation. The flicker noise current is modulated by the time varying gm of the device. Thus, his comment that it is the DC component of the ISF that matters is flawed.
To model this correctly, one should really consider flicker noise as being injected by a voltage source in series with the gate. Thus, you should perform you PAC analysis using a voltage source in series with the gate as your input and observe the +1 sideband.
I believe that with this more accurate model of flicker noise injection, Hajimiri's advice concerning symmetry breaks down.
