Dear all,
The LNA output is current output (output is from the drain of the transistor) and this current output will directly connect to the current input of the mixer (This is the connection point which is connected with the drain of the pmos current source at the upper and the drain of the communtating stage). Actually, I do not do conjungate matching between the LNA and Mixer because it is current conneciton. Now, I don't know how could I explain why do I need not to do conjungate match. PLEASE help me.....
![Embarrassed Embarrassed](https://designers-guide.org/forum/Templates/Forum/default/embarassed.gif)
Because traditional LNA is voltage output and it will connect to the gate of the transconductance transistor in the mixer. This is possible to do the matching network between these two blocks and give out the required bias at the same time.
HELP ME, THANKS
wccheng
