May 1st, 2024, 10:20am
Accumulating jitter (Read 2860 times)
wgfry7
Accumulating jitter
Oct 06th, 2004, 7:40am
In my platform I have basically two clock generators/PLLs, where one receives its clock from the other.  Of course, each PLL has its own jitter characteristics.  My question: does the jitter from the first PLL accumulated w/ the jitter from the second PLL?
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Re: Accumulating jitter
Reply #1 - Oct 6th, 2004, 8:19am
Low frequency or long term jitter from the first clock generator will appear in the output of the second unattenuated. However, the loop filter of the second PLL will filter out the high frequency jitter from the first. So at frequencies above the loop bandwidth of the second PLL, the only source of jitter will be VCO2.
Jitter Man
