Jun 30th, 2025, 7:48pm
Run time error in Verilog AMS (Read 3412 times)
Vivek Chandrasekhar
Guest
Oct 08th, 2004, 8:13pm
I got this error when i was simulating my 4 bit DAC code.
The error is
out_scaled = out_scaled + ((V(bit2) > vtrans) ? 4 : 0);: Expecting only branch or node type argument
The code is as under
`include "disciplines.vams"
`include "constants.vams"
module dac (out,bit3,bit2,bit1,bit0);
output out;
input bit3,bit2,bit1,bit0;
electrical out;
logic bit3,bit2,bit1,bit0;
parameter real vref  = 1 from [0:inf);
parameter real trise = 0 from [0:inf);
parameter real tfall = 0 from [0:inf);
parameter real tdel  = 0 from [0:inf);
parameter real vtrans  = 1.2;
   real out_scaled; // output scaled as fraction of 16
   analog begin
           out_scaled = 0;
           out_scaled = out_scaled + ((V(bit3) > vtrans) ? 8 : 0);
           out_scaled = out_scaled + ((V(bit1) > vtrans) ? 2 : 0);
           out_scaled = out_scaled + ((V(bit0) > vtrans) ? 1 : 0);
I would be grateful to anyone who could point out my error.
Thanks.
Vivek
  IP Logged
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Run time error in Verilog AMS
Reply #1 - Oct 9th, 2004, 12:38am
V() is an electrical access function. It should only be applied to electrical signals. bit2 is not electrical, it is logic. You would access the value of bit2 without the access function. So you should use ...
    out_scaled = out_scaled + ((bit2 > vtrans) ? 4 : 0);
- MM -
Reply #2 - Oct 12th, 2004, 1:58pm
In fact, it should probably be:
out_scaled = out_scaled + (bit2 ? 4 : 0);
No point comparing a logic signal to see if it is greater than vtrans...
jbdavid
Reply #3 - Nov 1st, 2004, 7:54pm
And actually
if you declared that as a 4bit wide bus, rather than 4 signals: you can make this much simpler..
module dac (output out, input [3:0] bit);
electrical out;
logic [3:0] bit;
parameter real vtrans  = 1.2; // not needed for d2a
   integer iout = 0; // output without x or z (init to 0)
always @(bit)
   if (^bit ==! 1`bx or ^bit ==! 1`bz) iout = bit;
 analog begin
         out_scaled =  out/16.0;
      V(out) = vref*transition(out_scaled, tdel, trise,tfall);
PS I do use some of  the verilog2001 enhancements..
they work in NCsim -ams..
jbd
jbdavid
jbdavid
Reply #4 - Nov 1st, 2004, 7:56pm
sorry
that should have been
outscaled = iout/16;
JBD
jbdavid
