May 20th, 2024, 1:35am
PSS simulation error-insufficient memory available (Read 7806 times)
rramp
Oct 13th, 2004, 10:33pm
Hi freinds !!!
I got some troubles during pss simulation - receiver top simulation.
The following error reported after spectreRF simulaiton
"Internal error found in spectre during check, during IC analysis, .... ..... Insufficient memory available"
So I wondered that my system has not sufficient memory and checked memory size. It has 7GB physical memory and 20GB swap memory.
Could you please give me advice for resolving this problem?
Re: PSS simulation error-insufficient memory avail
Reply #1 - Oct 14th, 2004, 10:11am
Please don't post in multiple fora - it just confuses things.
I've responded to your duplicate posting in http://www.designers-guide.com/Forum/?board=rfdesign;action=display;num=10977318...
