vakilia
Atlanta, GA
I am now workign on a mixed-mode sensor interface IC that requiers a very-low bandwidth filtering (0-0.01Hz). The sensor is capacitive with a -3dB frequency of 100Hz, so it needs on-chip noise band limitation anyway.
I myself am thinking of using high-order SC filters but there are two main problems: Large total capacitance and signal fading through the leakage of CMOS switches.
BTW I want to use sigma-delta modulator as well to generate digital output.
Do you have any suggestion how and where I could do the filtering in my circuit?
Thank you, Babak
