Or you may be using an old version before the fix to allow results files bigger than 2Gbytes. This was fixed a few years ago (I think in an IC445 or IC446 hotfix from memory). When you hit 2Gbytes in your PSF output data, it splits into multiple files (they show up as hidden (i.e. dot files) in the psf output directory).
