Apr 29th, 2024, 7:54pm
Different gain in Folded Cascode ???? (Read 3278 times)
Rave
Guest
Oct 24th, 2004, 11:32am
Hi All
I have a folded cascode amplifier. When i run an AC analysis with CMFB (its a transistor based CMFB which i wud replace later by SC-Cmfb) i get a gain of 60dB and UGF of around 55MHz.
But if i remove cmfb, and just connect load capacitance, i get gain of only 30dB and UGF of 35MHz.
Can someone suggest me why is that and which one should i consider correct.
  IP Logged
Paul
Switzerland
Re: Different gain in Folded Cascode ????
Reply #1 - Oct 27th, 2004, 8:31am
Hi Rave,
did you check your operating point in the second simulation. I expect one of the devices to enter triode region resulting in loss of gain.
Also check an earlier discussion of this issue:
http://www.designers-guide.com/Forum/?board=analog_design;action=display;num=107...
Paul
Andre
Guest
Reply #2 - Nov 15th, 2004, 4:29pm
Generally speaking a differential circuit will not work without the CMFB. Your output will saturate at either ground or vdd. The simulation will not be correct.
Use a Verilog-A CMFB if you want to evaluate the circuit without its effects.
  IP Logged
