May 18th, 2024, 10:32am
Balun hspice netlist (Read 104 times)
GiangHu
Nov 13th, 2004, 9:23am
Hi Ken,
The balun netlist that you posted in diff testbench
should be read as below:
The gain=0.5 not 2, if no "transformer" is included.
.subckt balun vid vic vi+ vi-
 E1 5 vic vid 0 0.5
 v1 vi+ 5
 F1 vid 0 v1 0.5
 r1 vid 0 1T
 E2 6 vi- vid 0 0.5
 v2 vic 7
 F2 vid 0 v2 0.5
 r2 7 6 1u
.ends balun
Thx
GiangHu
eskiyerli
Ex Member
Re: Balun hspice netlist
Reply #1 - Dec 31st, 2004, 8:52am
I had noticed the same thing. Ken gracefully changed the netlist. However, I still have my doubts about that circuit. I am getting strange results for S parameters. I think the problem is that the model is not truly reciprocal.
Murat Eskiyerli
  IP Logged
Reply #2 - Dec 31st, 2004, 9:28am
Can you quantify the problem. Say by analyzing some ideal circuits for which the S-parameters are known, and then contrasting the results you get versus the results you should get?
Reply #3 - Jan 2nd, 2005, 4:12pm
Guys,
    I've tracked down a second problem: the gain of the current controlled current sources should be negated. Here is the updated netlist:
* BALUN
* A bidirectional balanced-unbalanced converter.
* Maps between the unbalanced signals ‘d=1’ and ‘c=2’ and the balanced signals ‘p=3’ and ‘n=4’.
.subckt balun (1 2 3 4)
* Ideal transformer for the positive input
    E1 5 2 1 0 0.5
    V1 3 5
    F1 1 0 V1 –0.5
    R1 1 0 1T
* Ideal transformer for the negative input
    E2 6 4 1 0 0.5
    V2 2 7
    F2 1 0 V2 –0.5
    R2 7 6 1u
.ends balun
I have updated the paper on the site. Thanks for pointing out these problems.
eskiyerli
Ex Member
Reply #4 - Jan 7th, 2005, 9:29am
Thanks Ken,
I knew there was a problem as the I was getting 6dB S11 instead
-6dB at the input, but was too tired to track it.
Now, it seems to be working nicely.
Thank you,
Murat
  IP Logged
eskiyerli
Ex Member
Reply #5 - Jan 7th, 2005, 9:57am
I made a mistake in the earlier post. What I meant was that ac signal
at the input was +6dB instead of -6dB when matched.
Murat
  IP Logged
