May 21st, 2024, 8:06am
capacitive currents in MOSFET (Read 130 times)
miro masar
Guest
Nov 18th, 2004, 6:00am
I tried to examine (using spectre) to which freqency pinched MOSFET (BSIM3v3 model) acts as constant current soure. I gave constant dc bias on gate, dc bias on drain and superimposed ac voltage to drain and examined drain current.
I've expected capacitive current through drain to be w*Cdd*Vac, but it was 4-times bigger. Is the way I'm computing expected capacitive current wrong or why is there that difference?
thanks
miro
  IP Logged
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: capacitive currents in MOSFET
Reply #1 - Nov 18th, 2004, 8:37am
Isn't the current equal to 2*pi*omega*Cdd*Vac? The missing factor of 2pi would explain a factor of 6, meaning the capacitive current was actually a little less than you expected.
- MM -
gmork
Reply #2 - Nov 18th, 2004, 9:19am
As far as i remember from circuit theory lessons (it's been soooo far away), the admitance of capacitor is w*C so current should be w*Cdd*Vac=2*pi*f*Cdd*Vac.
I think the problem could be that i shouldn't use Cdd but some different capacitance(but which?)
miro
« Last Edit: Nov 18th, 2004, 10:34am by gmork »
Mighty Mouse
Here I come to save
the day!
Fantasyland
Reply #3 - Nov 18th, 2004, 3:54pm
Whoops! Sorry about that. Momentary brain freeze.
- MM -
Mighty Mouse
Here I come to save
the day!
Fantasyland
Reply #4 - Nov 18th, 2004, 4:00pm
Try looking at the posts by Andrew Beckett on MOSFET capacitances as reported by Spectre. You can find them at
http://www.designers-guide.com/Forum/?board=analog_design;action=display;num=108...
- MM -
gmork
Reply #5 - Nov 18th, 2004, 5:24pm
Thanks. As I see, I wasn't only one wich was confused about it. The correct expression for current is w*(cdd+cjd)*Vac and everything is consistent with AC simulation.
miro
