May 4th, 2024, 12:25am
SPICE simulation time and model (Read 1475 times)
Nov 24th, 2004, 12:38am
I am curious about the big difference between the simulation speed for two similar circuits. Would you please help me?
I have been redesigning a circuit using 0.25um CMOS technology. The original circuit was implemented using 0.35um CMOS technology.
The design has two oscillators, one very fast (~1GHz), the other slow (~1MHz for the original design, ~4MHz for the new design). So it takes so long time to run the transient simulation for both design.
But I am curious that the simulation time for the new design is much longer than that for the original design though both circuits has similar structure and spec.
It took near 300,000 seconds to run a 500us transient simulation using SPICE option method=gear. But it took more than 450,000 seconds to run just a 50us transient simulation using default integration method (trapzoid). As well known, transient simuation is much slower if using gear method. Sad So it makes me deep confused.
The detail statistics is shown below.
For the original design.
    analysis      time      # points  tot. iter  conv.iter
    transient    291621.51    500001  81511395  22966268 rev=******
For the new design.
    transient    409348.59      5001  45405049  12645293 rev=******
From the above data, the convergent iteration of the new design is about half of that of the original design. But remember it is a 500us transient simulation for the original design, and just a 50us transient simulation for the new design. That means the average internal time step is about 1/5 of that for the orignal design.
What makes the simulation for the new design interated so much times? And its internal time step smaller?
I notice one difference between the SPICE models for 0.35um and 0.25um. The SPICE model for 0.35um has a non-zero HDIF parameter(hdif=3.5e-7), but HDIF=0.0 for the 0.25um SPICE model. I suspect that will deteriorate the discontinuity of the 0.25um SPICE model. Thus SPICE tool need smaller internal time step and much more iteration.
I am not an expert in SPICE algorithm and MOS model. So I need your help!
What do you think the reason? Do you have any advise to speed the simulation?
Yawei
August West
I'll get up and fly
away
Re: SPICE simulation time and model
Reply #1 - Nov 24th, 2004, 8:36am
Yawei,
Your circuit is probably experiencing 'trapezoidal ringing'. You can generally confirm this by looking at the waveforms for the power supply currents. Trapezoidal ringing is occuring when the waveform alternates between being too high and too low on successive time points. To avoid it, switch to Gear.
This condition is well described in Kundert's book: "The Designer's Guide to Spice and Spectre".  Look at the section on 'Ringing" starting on page 150. This book is very good for answering these types of questions. Anyone running Spice should own a copy. You can find more information about it at http://www.designers-guide.com/Books/dg-spice/index.html.
-August
Reply #2 - Nov 28th, 2004, 5:32pm
Hi, August,
I modified the 0.25um SPICE model a little, assigned HDIF=2.5e-007, ACM=12. Now I am running a 200us transient simulation. The simulation speed almost doubles. So I think the model must have impacted the iteration and time step.
But it is still much slower than the simulation for 0.35um design. I will try method=gear following your advise.
Thanks very much.
Yawei
Reply #3 - Nov 29th, 2004, 6:36pm
Hi, August,
I checked the power supply current, it had very high frequency noise of several micro Ampere. I think that is trapzoidal ringing because it cannot be related to any behavior of that circuit.
So I run the simulation again with method = gear. To my disappointment, the ringing still exists, even not reduce. Sad It is strange as normally the trapzoidal ringing always disappear when the method is set to grear. The simulation speed decreases to one half, too.
Now I am runing a simulation using smaller transient step and method = gear.
.tran 1ns 50us
I found the simulation speed almost doubles than method = gear and 10ns step. It really confuses me.
Yawei
August West
I'll get up and fly
away
Reply #4 - Nov 30th, 2004, 8:06am
Trapezoidal ringing is always "point-to-point" ringing (alternating between too high and too low).  If it is not point-to-point ringing, or if it becomes smooth ringing as you tighten tolerances, or if it remains when not using trapezoidal, it is not trapezoidal ringing.
If it is not trapezoidal ringing, it must be your circuit itself. The reason why your simulations run so slowly is because it exhibits a parasitic oscillation or highly underdamped behavior.
-August
Reply #5 - Jan 10th, 2005, 2:30pm
Note that HDIF is used to compute AD, AS, PD, PS, which are used for junction capacitances.  The foundry may have expected you to use layout-extracted values for these parameters, in which case HDIF is not necessary.
Obviously, these capacitances can smooth out the circuit response; I'm not sure if this is what you meant by "deteriorate the discontinuity of the 0.25um SPICE model."
