May 1st, 2024, 11:10pm
compiling error (Read 2725 times)
ppm
compiling error
Dec 03rd, 2004, 12:02pm
Can someone help me correct the error below:
ground gnd;
I have "illegal ground node 'gnd' " error with the above statement?  I read from Ken's paper, PLLnoise.pdf, that "this ground statement is not currently supported in Cadence's Verilog-A implementation, so instead ground should be explicitly passed into the model through a terminal. "
How do I do that???   Help please?!?
ppm
Re: compiling error
Reply #1 - Dec 3rd, 2004, 2:04pm
Add it as a terminal of the module and pass it in from the top level.
