Jul 2nd, 2025, 6:08am
Named Port Association in Verilog-AMS (Read 4382 times)
Vikram Srinivasan
Guest
Dec 18th, 2004, 11:47pm
Hi
I was designing an RC network and I decided to have 3 modules in my source file-2 for definitions of the resistor and capacitor and the main module where instances of the R and C were created(with the appropriate interconnection). This is the code I wrote:
module rescap(posr,negc);
electrical posr,negr,negc;
resistor res(.p(posr),.n(negr));
capacitor cap(.pos(negr),.neg(negc));
module resistor(p,n);
parameter real rn=1k from [1:inf];
electrical p,n;
analog
begin
V(p,n) <+ rn*I(p,n);
module capacitor(pos,neg);
parameter real c=100 from [1:inf];
electrical pos,neg;
analog
begin
I(pos,neg) <+ c*ddt(V(pos,neg));
My test bench file looks like this:
module rctest(posr,negc);
electrical posr,negc;
wire negr;
resistor #(.rn(1000)) res(p,n);
capacitor #(.c(100)) cap(pos,neg);
vsource #(.type("sine"),.dc(0),.ampl(5),.freq(5000)) vin(posr,negc);
Now when I compile this, I get an error message that "Named Port Association is not valid for analog primitives in Affirma-AMS". I am confused. I thought named port association was valid in V-AMS.
Am I missing something?
  IP Logged
Mighty Mouse
Here I come to save
the day!
Fantasyland
Re: Named Port Association in Verilog-AMS
Reply #1 - Dec 20th, 2004, 9:58am
Named port associations seem like they should work. Kundert included an example of it in his book (see listing15 in chapter 4 at http://www.designers-guide.com/Books/dg-vams/index.html), and he claims they were all tested in AMS-Designer. Perhaps the fact that you have chosen names for your modules that are exactly the same names used for the built-in primitives is confusing things. Try myres rather than resistor, etc.
- MM -
Vikram Srinivasan
Guest
Reply #2 - Dec 20th, 2004, 11:15am
Thanks MightyMouse !! I'l try that !
  IP Logged
