May 4th, 2024, 2:23am
HOW TO TEST CHIP IN HIGH AND LOW TEMPERATURE? (Read 2997 times)
Dec 22nd, 2004, 12:21am
I wanna know how to test chip in high and low temperature. I am doing measurement in lab.
Yawei
vivkr
Re: HOW TO TEST CHIP IN HIGH AND LOW TEMPERATURE?
Reply #1 - Dec 6th, 2005, 2:31am
Hi Yawei,
In principle, you need a temperature chamber if you want uniform control over the testing. There are several. We have one from Siemens.
But if you want to do it quick and dirty, then you can use a hair-dryer to get
the high-temperature end, while for low-temperature, there are these cans of coolant (aerosol-like). Unfortunately, I don't know what these are called. Perhaps someone can suggest.
Vivek
