Aug 17th, 2024, 11:52pm
does low vth transistor have larger bandwidth? (Read 2426 times)
sugar
Jan 06th, 2005, 6:56am
in a differential buffer circuit, if we use low threshold voltage transistor pair, can we get larger bandwidth?
101questions
Re: does low vth transistor have larger bandwidth?
Reply #1 - Jan 9th, 2005, 1:30pm
Depends. If low Vth allows you increase currents and vdsat, there is a good chance you buffer would be faster. Again, it depends on how you utilize the additional voltage headroom and if it can be used at all due to other restrictions.
