Jul 18th, 2024, 5:17am
power supply rejection (Read 6462 times)
Won
Jan 12th, 2005, 3:37pm
I'm trying to simulate the power supply jection of OPAMP.
But, I'm not sure my simulation method is correct or not.
I designed the simple  OPAMP with 60dB gain
And I'd like to simulate the power supply jection.
So, I give AC signal at power source (VDD) and I tied the output singal to one of inputs of OPAMP.
Is it correct?
And I have another question.
If OPAMP have resistor feedback, how to simulate the PSRR ?
should I connect the output and other input not to be connect with feedback node, and simulate AC analysis?
Won
Erez_Sarig
Re: power supply rejection
Reply #1 - Jan 23rd, 2005, 1:27am
Hi.
You are doing OK .
You can measure PSRR by keeping the OPAMP in closed loop and apply AC=100 on the supply, in this way you will get exactly the % of noise injected to the OPAMP output. This is correct also when using a Resistor in feed back.
Erez Sarig
Mighty Mouse
Here I come to save
the day!
Fantasyland
Reply #2 - Jan 23rd, 2005, 11:20am
The PSRR is simply the ratio of the gain of your circuit from its normal input to the gain of your circuit for a signal injected on the power supply.
PSRR = Ain / Asupply
where
Ain = vout / vin with vsupply = 0
Asupply = vout / vsupply with vin = 0
Thus, you should configure your opamp as you expect it to be used, and then perform two AC analyses, one where the normal input is driven and one where the supply is driven. With Spectre, you can get the same information using one XP analysis.
- MM -
richloo
Reply #3 - Jan 26th, 2005, 5:39am
Can u teach me to run XF analysis in spectre simulator? including the circuit connection.
Thanks in advance!
Mighty Mouse
Here I come to save
the day!
Fantasyland
Reply #4 - Jan 26th, 2005, 2:11pm
The XF analysis is very similar to the AC analysis, except that while AC allows you to specify a specific source and see the response at any possible observation point; XF allows you to identify a particular observation point, and compute the transfer function from every souce to that point.  (This should all be explained by running "spectre -h xf".)
To use XF, you must identify the observation point, which is typically the output of your circuit. This is generally done by specifying a pair of nodes. Then you would specify the start and stop frequencies just as you would with AC. Then run the analysis. Then the transfer function from every source in the circuit to the observation point is available in the analysis results. To find the PSRR  compute Vin/Vdd if Vin is the name of your input source and Vdd is the name of your supply.
- MM -
richloo
Reply #5 - Feb 6th, 2005, 11:20pm
Thanks MM, i've setup the testbench and run the analysis, but i get db20(1/vcm), db20(1/vdd) only a strainght line of -6.4KdB.
I've have enter 10mV in the XF magnitude vsin source. can u help me out?
Thanks in advance~!!!
Mighty Mouse
Here I come to save
the day!
Fantasyland
Reply #6 - Feb 7th, 2005, 11:23pm
You should probably not set the xfmag. If you leave it alone it defaults to 1, meaning that it will directly compute the transfer function.
I cannot understand why the computed result is -6.4kdB. That indicates that there is no path from the supplies to output of the circuit. Did you properly specify the circuit output to the XF analysis?
- MM -
