stephen
I want to start a spectre simulation on another host. In the simulator setup dialog of Analog Simulation Environment, I chose the simulation mode to be "remote". I need supply another two fields, which are "host" and "remote directory". I put the domain name of the remote host in the host field and put a full path name in the remote directory field. I got an error: "unable to connect to the host: pcname.abc.com".
What's wrong? Cadence was installed on both local host and the remote host.
Thanks.
