May 17th, 2024, 11:01pm
Find MOS operation region in spectre calculator (Read 11282 times)
gogomi
Jan 20th, 2005, 12:10pm
Does anyone know the meaning of operation region from spectre calculator? The device operation region was represented by some
numbers and I have no idea what is these numbers mean.
Here is the command in spectre: OP("/N0" "region").
Thanks!
gogomickey
mohammad
Re: Find MOS operation region in spectre calculato
Reply #1 - Jan 20th, 2005, 1:51pm
I think the numbers are as follows:
0 off
1 Triode
2 Saturation
3 Subthreshold
M.H.
gogomi
Reply #2 - Jan 20th, 2005, 9:52pm
Got it! Thank you very much!
gogomickey
Reply #3 - Jan 21st, 2005, 1:04am
If you run "spectre -h dev" where 'dev' is the name of the device for N0, you will see the complete list of possible values for the region parameter. The number corresponds to the index for the values in this list starting from 0.  So 0 would correspond to the first item in the list, 1 to the second in the list, etc.
