Mahbub Reja
Guest
Jan 25, 20045
Hi everyone, I have a problem with running simulation at different temparature. In the Analog design environment window, I see the Temp=27 0C. If I go to the simulation->Analog-> Temparature options, then I see the following. temp=27 0C tnom= 27 0c
If I change the "tnom", my simulation results do not vary. But if I change the "temp" (0 0C to 100 0C), my simulation results completely different than at 27 0C.
My question is that how the simulator analysis temp (27 0C) is related with the real world temparature or actual circuit and its devices parameters. How, I can determine, whatever the temparature from 0 C to 100 0C, the simulation results do not change. What is the difference between the actual circuit temparature and the analysis temparature.
Best regards
Mahbub Reja
