There are several ways.
In the new waveform tool (wavescan), you need to double click on the x-axis, and you'll get the Axis attributes dialog appear. On this, you can click the cyclic next to "Plot vs" and pick the signal you want to use as the x axis. You'd then need to use the "xval" function in the calculator to get a waveform with the x-axis as the y-axis (if you see what I mean).
In AWD (the old waveform tool) the process is exactly the same, in fact - but you need to have plotted the signal you want to have as the x-axis (so you'll need to plot the signal and the xval'd signal).
Or you might just want to use this SKILL code:
Code:(procedure (abTransposeXY var)
(let (newWave)
(setq newWave (drCreateEmptyWaveform))
(drPutWaveformXVec newWave (drGetWaveformYVec var))
(drPutWaveformYVec newWave (drGetWaveformXVec var))
newWave
(sorry, the indentation seems to have got scuppered by YABB here)Get the signal in the calculator buffer, and then change it
to:
Code:abTransposeXY(expression)
where expression is the expression to plot the signal you want to transpose.
