May 15th, 2024, 4:48am
"amsdirect not found" (Read 4111 times)
akvarma
Jan 27th, 2005, 8:59am
I am running ic5033/ld51 and I am trying to run Cadence tutorial for AMS Designer.
When I do a run from AMS->Design Prep->Run, I get an error saying "amsdirect not found".
I have setup all the paths and I can even see amsdirect from the command line.
Not sure what I need to do for this thing to have a successful run.
Thanks for any help in advance.
Ambrish.
Re: "amsdirect not found"
Reply #1 - Jan 28th, 2005, 10:51pm
Hi Ambrish,
The only references I could find to this problem were a little vague as to the cause - except they did indeed get solved ultimately somehow! One case was because the product had not been installed (don't think that's your problem), one was because of a lack of AMS_environment license feature, and one was fixed by installing a later hotfix. Perhaps you could get IC5033 USR3?
akvarma
Reply #2 - Jan 31st, 2005, 11:48am
Thanks for that.
Well - its not as easy as it sounds to install USR3 sitting behind a university machine.
Something inside me says that I am not setting the LD_LIBRARY_PATH environment correctly.
The tutorial asks to "Add the location of the AMS Designer software libraries to the search path specified with the LD_LIBRARY_PATH environment variable.
setenv LD_LIBRARY_PATH ${AMSHOME}/tools/lib:${CDSHOME}/tools/lib"
Has anybody run the tutorial successfully?
Thanks.
Ambrish.
Reply #3 - Jan 31st, 2005, 9:39pm
I have run it successfully before.
I don't think LD_LIBRARY_PATH would necessarily have anything to do with it -  but you might as well try it.
akvarma
Reply #4 - Feb 18th, 2005, 9:35am
Just for the records,
We fixed the error with the help of Cadence support.
Seems there was a bug in IC5033 USR2. We had to change directory permissions for the amsdirect executable and thats it.
Thanks.
Ambrish.
