Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Oct 18
th
, 2024, 4:03am
Home
Help
Search
Login
Register
PM to admin
Measurements
Phase Noise and Jitter Measurements
› Jitter Measurement vs Simulation
Previous topic
Next topic
Jitter Measurement vs Simulation (Read 3204 times)
ic_engr
Feb 16
th
, 2005, 12:23pm
Hello Everyone,
I was trying to design an oscillator with a known jitter. I also had an existing oscillator in 0.18um technology. The measured jitter in TIE of 30us was 1.4nsec. The period jitter was 483psec. The oscillator frequency is 4MHz.
I used tdnoise in Spectre to predict the jitter for the oscillator for which I have measured results. When I integrated the noise on the tdnoise form from 33.3kHz to 2MHz (fo/2) as in Ken's paper, I got 10.4mV. I divided this number by the SR of the ring oscilltor (6.5MV/sec) and I got 1.6nsec. This is pretty close to what I have on silicon (1.4nsec measured). DId I do anything stupid here!.
Can anyone tell me if I did the right thing by intergating from 33.3kHz to 2MHz. If I integrate from a lower frequency (1kHz to 2MHz) I see the jitter is prety large due to 1/f contributions. the fc is at 10kHz.
Using the same strategy I predicted the jitter for my new oscillator and it seems to be about 14pSec when integrating 33kHz to 2MHz.
I thuought I should have multiplied by sqrt(fo*30us) for k-cycles jitter. Did I already take care of it by doing integration from 33kHz to 2MHz.
Does the multiplication factor for k-cycles jitter only comes in when tdnoise is integrated at higher frequencies.
I set the sweep in pnoise for tdnoise to absolte.
Any suggestions will be appreciated.
ic_engr
IP Logged
Tommy
Guest
Re: Jitter Measurement vs Simulation
Reply #1 -
Feb 17
th
, 2005, 8:53pm
Iam no expert in this. But if I have followed my math correctly, that integration gives a 1-sigma value of Phase jitter.
I think a better approach to simulate jitter would be to use voltage-domain behavioural model of the oscillator & dither its timing events (The dithering value should be calibrated from the circuit as described by Ken in the Jitter paper). You could dump the threshold crossing times of the oscillator to a file & use the formulas to compute whatever jitter metric you want to compute by writing an appropriate Matlab script (or a C program).
Tommy
IP Logged
Reply #2 -
Apr 5
th
, 2005, 8:02pm
Can you explain the measured jitter in TIE, period jitter, and phase jitter for me and their relationship? It has many definitions for jitter. Sometimes I am confused.
I will appreciate very much.
Yawei
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
»» Phase Noise and Jitter Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
