Sep 17th, 2024, 4:12am
How to convert the phase noise to jitter? (Read 1781 times)
zoujunjx
Apr 06th, 2005, 6:06am
First of all, thanks a lot for what you have done for us. I am new for researching the PLL circuit.
About the paper "Predicting the phase noise of PLL-based frequency synthesizers ", I have still unclear questions.
Question 1
In the list3 a behavioral model of VCO, you use a flicker_noise function to describe the phase noise spectrum, how to get the value of jitter ? Which simulation we can make on the beahvioral model to get the phase noise spectrum, is it still PSS and Pnosie? and which simulation for the value of jitter?
Question 2
In veriloga model library on your web, I have seen another beavioral model for VCO with jitter. The jitter is as a parameter of the model, can be direcetly setup.
In my opinion, the jitter depends still on the offset frequency. so if we want to get a value of jitter, we need firstly determine which offset freqeuncy we concern.
Question 3
In the phase noise spectrum, the L(fm) can be seen as a piece-wise function of a offset frequency fm.
for example, form 1Hz to 100Hz, the slope is -30dBc/decade; form 100Hz to 1M, the slope is -20dBc/decade.
I want to know whether in each slope has the same value of jitter, which means there is a jitter (J1) vaule between 1Hz to 100Hz, and another vaule (J2) for the frequency between 100Hz to 1M.
Thanks for your help!!!
