With PXF the frequency range that you specify on the analysis is always the frequency range of the observed signal. Thus, since you specified 1Hz to 10MHz absolute, that is what you get. So you are measuring the transfer function from VDD from baseband to baseband.
For PSR for an oscillator, you probably want the transfer function from baseband to the carrier. So will want to use a relative sweep. That would cause the output frequency of your transfer function to range between f0 + 1Hz to f0 + 10MHz. When plotting VDD, you will need to choose the +1 sideband (or perhaps it is the -1 sideband, I always forget, use 'spectre -h pxf' for find out for sure). This will result in you computing the transfer function from 1Hz --> 10MHz to f0 + 1Hz --> f0 + 10MHz.
If you chose the output as a pair of node and the input as a voltage source (VDD), then the transfer function will be the voltage gain from the source to the output nodes. So a result of 40dB @ 1Hz would imply that a 1Hz signal at VDD is amplified by a factor of 100 before appearing at the output at f0 + 1Hz.
You do not have to set mag or pacmag on the source.
