May 18th, 2024, 4:10pm
Simulating an injection-locked frequency divider (Read 3007 times)
Alez
Guest
Feb 22nd, 2005, 8:42am
Dear all,
I'm trying to simulate a small system containing a VCO
and an injection-locked frequency divider (ILFD).
In this simulation, I created a VCO runing at a frequency
of f_h and created another VCO which is used as the
ILFD runing at half of f_h.
My question is, since the simulation containing two
circuits which run at different frequency,
"How should I select the frequency in the PSS
simulation of SpectreRF" ?
Thank you so much,
Alez
  IP Logged
Re: Simulating an injection-locked frequency divid
Reply #1 - Feb 22nd, 2005, 10:35am
To simulate with SpectreRF the two oscillators must be locked, so that there is only one fundamental frequency, which would be the output of the divider. This is the frequency you give to SpectreRF. Then the other frequency, that of the VCO, appears to be a harmonic of the fundamental.
